deusex:// and domain names
Postby Shinobi » Sun Jul 24, 11 3:15 pm
I want to make a way for someone to join a server not in list, I don't have static ip, but have no-ip darkglobe87.servebeer.com
want a way to make shortcut or something so other person can connect to server using this name, but dx ip box only allows... well, ip's.
Possible? If so, how?
Postby Dae » Sun Jul 24, 11 4:05 pm
You can use the "open" command which should work with domains.
I don't remember whether you should specify the port though, either or both of those
open darkglobe87.servebeer.com
open darkglobe87.servebeer.com:7790
should work if everything is configured correctly (e.g. port forwarding).
The link such as this
deusex://darkglobe87.servebeer.com
should also work straight from the browser... if it doesn't you need to install a special patch for that which I believe was posted somewhere on this forum ages ago :P
Postby Shinobi » Sun Jul 24, 11 5:44 pm
It's in the archive, or if ya got moop's map pack it's in ther too.
I know open command, but would like a shortcut or somethign from desltop if possible?
Postby Dae » Sun Jul 24, 11 6:01 pm
You could make an URL file or a .BAT with something like this:
DeusEx.exe darkglobe87.servebeer.com
I don't know if it works though.
Postby Shinobi » Sun Jul 24, 11 6:04 pm
URL file? Just read link. New to me, that is.
I can't be bothered with batch file. Nevermind.
Btw totally random... from dx.log:
Init: Memory total: Phys=4194303K Pagef=4194303K Virt=2097024K
Init: Working set: 32000 / 159000
Init: CPU Speed=3073.632549 MHz
Init: CPU Page size=4096, Processors=8
Init: CPU Detected: PentiumPro-class processor (GenuineIntel)
Init: CPU Features: CMov FPU RDTSC PAE MMX KNI
WUT NO SSE2 lol
Postby ~ô¿ô~Nobody~ » Sun Jul 24, 11 8:27 pm
Using the open command with domain:port works.
@SSE2
Obviously that's soo common that they accidentally forgot to put it in your CPU. :P
Postby Shinobi » Mon Jul 25, 11 12:15 am
deusex://darkglobe87.servebeer.com open DeusEx... that's about it. No server connection?
Postby Dae » Mon Jul 25, 11 8:57 am
Does it work in-game with open deusex://darkglobe87.servebeer.com?
Try the protocol fix attached below, again. Set the correct path to your Deus Ex installation in xp.reg.
dxmp-url_protocol.zip
(1.51 KiB) Downloaded 1016 times
Postby Shinobi » Mon Jul 25, 11 10:33 am
Cheers, Dae, solved the problem, I tried a different file supposed to do the same but this one works.
