ConEdit
ConEdit
Postby Spiderbot01 » Sat Jan 02, 10 4:55 pm
Right, Ive got a .con file, it has all the conversations for a map. I also have the map (funny that).
You know you have to do something clever to the file using command prompt or something. Basically I don't understand how to do it and have tried on numerous occasions. Is anyone here able to give me a hand?
Postby Jon » Sat Jan 02, 10 8:37 pm
format c:
Postby Spiderbot01 » Sat Jan 02, 10 9:51 pm
Ive tried what it says on the old tack website, but it never seems to work :(
Postby Mastakilla » Sat Jan 02, 10 10:15 pm
[PMS]LONGCAT wrote:Ive tried what it says on the old tack website, but it never seems to work :(
Go through all the steps again, it should work, I've done it with guidance of Tack's website aswell...
Postby Spiderbot01 » Sat Jan 02, 10 10:55 pm
Right I keep getting an error in command prompt. Saying it cant find *.uc in the right folder. Ive created a folder named exactly what it should be and created notepad files called 'x.uc' etc, but it wont work, any help?
Postby Dae » Sat Jan 02, 10 11:43 pm
[PMS]LONGCAT wrote:notepad files called 'x.uc'
this sounds a little strange
are you sure they're not x.uc.txt, with .txt part being invisible?
Postby Spiderbot01 » Sat Jan 02, 10 11:49 pm
You are indeed right, and I thought that would be wrong, but I have no idea how to give them the uc extension rather than txt
Postby Dae » Sat Jan 02, 10 11:54 pm
Postby Spiderbot01 » Sun Jan 03, 10 12:03 am
It is a .txt file. How do I make it a .uc file?
Postby Dae » Sun Jan 03, 10 12:26 am
and remove .txt, god damn it!
Postby Spiderbot01 » Sun Jan 03, 10 12:32 am
Thats incredible. You and your russian wizardry.
Been saying analyzing for quite some time though.
Postby Spiderbot01 » Sun Jan 03, 10 1:06 am
I have now hit a new problem. I start up the map and the barks of some characters I have created work, however the actual conversations I have created don't seem to work for anyone. And in one case neither their conversation nor barks will work at all.. any ideas?
