Strange error while launching level, please help! (log inside)
Postby Zondartul » Thu Mar 26, 09 5:55 pm
I have some error that won't let me "play level" from unrealEd. I think it has something to do with LevelInfo object.
Here is log:
Log: Log file open, 03/26/09 18:48:17
Init: Version: 1100
Init: Command line: Autoplay.dx HWND=1246644 -log -hax0r
Init: Base directory: C:\DeusEx\System\
Init: Character set: Unicode
Log: Bound to Engine.dll
Log: Bound to Core.dll
Log: Bound to Window.dll
Log: Cd Path: D:\
Init: Computer: USER7FEE1EA33B
Init: User: Svetlana
Init: Memory total: Phys=2097151K Pagef=4194303K Virt=2097024K
Init: CPU Speed=2664.124882 MHz
Init: CPU Page size=4096, Processors=2
Init: CPU Detected: PentiumPro-class processor (GenuineIntel)
Log: Bound to DeusEx.dll
Log: Bound to Extension.dll
Log: Bound to ConSys.dll
Log: Loading: Package DeusEx
Log: Loading: Package Core
Log: Loading: Package Engine
Log: Loading: Package Extension
Log: Loading: Package DeusExCharacters
Log: Loading: Package DeusExUI
Log: Loading: Package DeusExItems
Log: Loading: Package Effects
Log: Bound to Fire.dll
Log: Loading: Package Fire
Log: Loading: Package ConSys
Log: Loading: Package DeusExSounds
Log: Loading: Package DeusExDeco
Log: Loading: Package UBrowser
Log: Loading: Package UWindow
Log: Bound to IpDrv.dll
Log: Loading: Package IpDrv
Log: Bound to DeusExText.dll
Log: Loading: Package DeusExText
Log: Loading: Package Ambient
Log: Loading: Package MoverSFX
Log: Loading: Package IpServer
Log: Loading: Package MPCharacters
Log: Bound to WinDrv.dll
Init: Mouse info: 6 10 1
Init: Client initialized
Log: Bound to Render.dll
Log: Loading: Package Render
Init: Lighting subsystem initialized
Init: Rendering initialized
Log: LoadMap: entry.dx
Log: Loading: Package Entry
Log: Loading: Package Title_Music
Log: Loading: Package MMUserInterface180
Log: Loading: Package DXMTL152b1
Log: Game class is 'MMUIGameInfo'
Log: Bringing Level Entry.MyLevel up for play (0)...
DXMTL: InitGame:
DXMTL: Base Mutator: Entry.CBPMutator0
Log: Browse: Autoplay.dx?Name=Zonda?Class=MMUserInterface180.MMUIPlayer?Team=128
Log: Doing load, not loadgame
Log: Current mission number is -1, next is -1
Log: LoadMap: Autoplay.dx?Name=Zonda?Class=MMUserInterface180.MMUIPlayer?Team=128
Log: Loading: Package Autoplay
Log: Loading: Package UNATCO
Log: Loading: Package CoreTexDetail
Log: Loading: Package CoreTexMetal
Log: Loading: Package NYCBar
Log: Loading: Package CoreTexStone
Log: Loading: Package Constructor
Log: Loading: Package CoreTexWood
Log: Loading: Package CoreTexMisc
Log: Loading: Package CoreTexGlass
Log: Loading: Package Paris
Log: Loading: Package CoreTexWallObj
Log: Loading: Package CoreTexTextile
Log: Loading: Package CoreTexTiles
Log: Loading: Package NewYorkCity
Log: Loading: Package V_Com_Center
Log: Loading: Package Mobile_Camp
Log: Loading: Package CoreTexPaper
Log: Loading: Package CoreTexConcrete
Log: Loading: Package CoreTexWater
Log: Loading: Package area51textures
Log: Loading: Package CoreTexCeramic
Log: Loading: Package CoreTexFoliage
Log: Loading: Package UNATCO_Music
Log: Collecting garbage
Log: Purging garbage
Log: Unloading: Package Render
Log: Garbage: objects: 37913->37838; refs: 557365
Log: Bringing Level Autoplay.MyLevel up for play (0)...
DXMTL: InitGame: ?Name=Zonda?Class=MMUserInterface180.MMUIPlayer?Team=128
DXMTL: Base Mutator: Autoplay.CBPMutator1
Log: DeusExLevelInfo object missing!  Unable to bind Conversations!
Init: Initialized moving brush tracker for Level Autoplay.MyLevel
ScriptLog: Team 128
ScriptLog: Login: Zonda
Critical: appError called:
Critical: MMUIGameInfo Autoplay.MMUIGameInfo1 (Function Engine.GameInfo.Login:01BC) Runaway loop detected (over 10000000 iterations)
Exit: Executing UWindowsClient::ShutdownAfterError
Critical: FFrame::Serialize
Critical: UObject::ProcessEvent
Critical: (MMUIGameInfo Autoplay.MMUIGameInfo1, Function DXMTL152b1.MTLGameInfo.Login)
Critical: ULevel::SpawnPlayActor
Critical: UGameEngine::Init
Critical: XGameEngineExt::Init
Critical: DDeusExGameEngine::Init
Critical: InitEngine
Exit: Exiting.
Uninitialized: Log file closed, 03/26/09 18:48:23
I'm basically trying to run a recompiled unatco headquarters-based map with rooms changed around, some of them copied. So this could also be due to some actor copied that is meant to be unique.
Zondartul
Postby MainMan » Thu Mar 26, 09 6:08 pm
change your default GameInfo to MTLGameInfo from MMUIGameInfo
Postby Zondartul » Thu Mar 26, 09 8:20 pm
Gives me the same exact error, except now it says: "MTLGameInfo Autoplay.MTLGameInfo1 (Function Engine.GameInfo.Login:01BC) Runaway loop detected (over 10000000 iterations) "
Zondartul
Postby Alex » Thu Mar 26, 09 8:52 pm
Not sure if it was the issue, but check if you don't have two or more DeusExLevelInfo's (So the class 'DeusExLevelInfo') in your map.
Postby ~DJ~ » Thu Mar 26, 09 9:43 pm
Have you tried Minimizing just after pressing the Play map button?
Postby Zondartul » Fri Mar 27, 09 1:33 pm
I don't have multiple DeusExLevelInfo's in my map.. actually I didn't have even one. I added one, now the log is 5 times shorter:
Log: Log file open, 03/27/09 14:29:51
Init: Version: 1100
Init: Command line: Autoplay.dx HWND=525866 -log -hax0r
Log: Cd Path: D:\
Init: CPU Speed=2664.051638 MHz
Log: Game class is 'MTLGameInfo'
DXMTL: InitGame:
Log: Browse: Autoplay.dx?Name=Player?Class=DeusEx.JCDentonMale?Team=128
Log: LoadMap: Autoplay.dx?Name=Player?Class=DeusEx.JCDentonMale?Team=128
Log: Garbage: objects: 37771->37696; refs: 553589
DXMTL: InitGame: ?Name=Player?Class=DeusEx.JCDentonMale?Team=128
Log: Loading: Package DeusExConText
ScriptLog: Team 128
ScriptLog: Login: Player
Critical: MTLGameInfo Autoplay.MTLGameInfo1 (Function Engine.GameInfo.Login:01A1) Runaway loop detected (over 10000000 iterations)
Critical: (MTLGameInfo Autoplay.MTLGameInfo1, Function DXMTL152b1.MTLGameInfo.Login)
Exit: Exiting.
Uninitialized: Log file closed, 03/27/09 14:29:59
Zondartul
Postby Kaiden » Fri Mar 27, 09 5:34 pm
I say it's a problem with MTL, try to re-install it, although not too sure.
Postby Mastakilla » Fri Mar 27, 09 5:42 pm
Is your computer plugged in? It is very much common mistake.
/foamy
k soz
Postby MainMan » Fri Mar 27, 09 6:09 pm
Kaiden wrote:I say it's a problem with MTL, try to re-install it, although not too sure.
No, ignore this.
It has nothing to do with MTL. It looks very much like something native to the Editor, as it's sending an incorrect string to the login function
Postby Zondartul » Mon Mar 30, 09 12:03 am
So does anyone know what else could I do to fix this? I tried even launching the map from deus but got same error. It said UnatcoWentInsane.MTLGameInfo2. When I browse from the ditor I can't see even one. DXMTL is installed but it's not in editor packages. Maybe I put it in the list and then put another game info inside?
Zondartul
Postby MainMan » Mon Mar 30, 09 12:56 am
Don't put a gameinfo in your map.
